c.nordstrom
World Traveller Extraordinaire
TeraFlex JK Wrangler SpeedBumps Bumpstops
Murray, Utah- September 9, 2009. TeraFlex Inc., manufacturer of TeraFlex suspensions, body protection equipment, low range gearing and HD axles, introduces the newest suspension component for the JK Wrangler.
TeraFlex SpeedBumps are an innovative composite bumpstop system designed for high-speed, high-performance JK Wrangler applications. The maintenance free, performance tuned microcellular polyurethane technology provides a simple installation with no further adjustment or tuning required for a lifetime of dedicated off road use.
TeraFlex SpeedBumps have the following features:
• JK Specific tuned for high speed performance
• Simple installation - no welding required
• Quiet movement & function (no pad-slap clunk)
• Absorbs large impact energy progressively during compression to prevent bent axle tubes
• Maintenance free, all-composite construction
• Resistant to all types of conditions (mud, salt, sand, dust, etc.)
• Compatible with all suspension systems that retain factory axle & spring mounting locations
• High compression rate with full memory rebound
• Engineered for maximum lifetime compression cycle
• Unsurpassed dynamic performance
• Maximum low temperature flexibility reduces fatigue & premature failure in subzero conditions
• Patent Pending technology
TeraFlex SpeedBumps start at a suggested retail price of $409.99 a pair. Applications for the TJ Wrangler will be available shortly.
TeraFlex products are available direct, or through authorized TeraFlex Dealers. For a complete list of Dealers in your area, or to purchase direct, contact TeraFlex at 801-288-2585 or visit them on the web, www.teraflex.biz.
About Teraflex - Since 1997, TeraFlex has been a dominant force in the off-road Jeep market. TeraFlex was the first suspension manufacturer with a suspension system for the TJ Wrangler, and is still the only aftermarket company to offer a solution for the venerable 231 transfer case's low range gearing. Continuing their stronghold, they offer some of the most dependable performance components for the JK Wrangler available today.
