mtnbike28
OK I am in the middle of the CB install and went to Radio Shack and bought a $50 SWR Meter... but not the darn cable between the meter and CB (why can't they include that?) I ran power to the CB with RA 58 shield cable directly to the battery (read that tip on the internet). So I spliced together the ends from the the cut up RA58 cable I used for power to make a short antenna cable to connect the meter and CB - is this bad, ie messing up my SWR readings? I just want to use it long enough to test SWR. I tested the continuity and it buzzed...
Thanks
Thanks
