The AKPostal
akpostal
Decided on the M-PAC
akpostal
Borrowed one of Scherb's ideas.
Leaving it filled upright overnight for a leak test, will flip it tomorrow for another leak test.
I plan to mount it under the Action Packer on the rack, Ill get better then half the gallon mounted and can pull it from the mount to get the rest and refill.
Ill add a spigot and vent to the Rubican when it gets here and mount it to the front drivers fender mount when that gets here.
akpostal
Mounted the water pack to the rack. Problem is the Action Packer or cooler needs to be pulled to get at the vent.
ETA: Turns out I can open the gate to get to the vent from the back.
akpostal
I could actually strap my 16' Aire Jag on the roof rack if I wanted to, Ild need help but its doable.
akpostal
Broke my rule of putting food in my drinks cooler over the winter, now it needs to be heat pressure wash cleaned and scrubbed.
Ill only run the lower rack on day trips or if Im sleeping in someone elses tent/camper/cabin.
akpostal
Got my fender mounts and Rubican in today. I only did the driver side because I wanted to try the vent and spigot on the Rubican. The caps I have are smaller then the Rubicans neck so Ill have to do what Scherb did and cut some plastic and DIY. I did get the vent installed.
Very easy to install and stable. Once I install the CB the drivers side will stay on as the antenna mount, I may not leave the passenger side on unless I need it for more gas.
akpostal
Because it was bugging me I decided to try and make the cap the Rubican came with work with the spigot, so far it has. Ill be checking it for leaks but so far looks good.
And while I was digging threw the boxes, Retrofit already delivered with a sticker so 2 fingers up.
akpostal
Mounted another Rotopax mount for a water pack I have on the way. The Pack in the pictures is for the rear rack so its upside down, the can that will go there will be vented up and spout pointed down.
akpostal
ETA: Correction, the side mounts are a product from MORryde.com purchased from Retrofitoffroad.com.
