silvrzuki77
explorer
Ditto! I learned alot from your build.
jim65wagon said:“The other failure was probably the worst thing that could have failed:The trailer tongue. Yes the tongue. It slowly bent in the first summer of use (of course the warranty on the trailer was out by that point), we managed to straighten it (with the truck and a floor jack)enough to slide a piece of 3/16" steel inside it and finished the season. We watched it throughout this season, and while it did not bend any further the original aluminum tongue continued to flex enough to crack completely around the circumference. After our trip with the Camp Inn trailer crowd we had to do something about it and found a trailer company in Maryland that did aluminum trailer repair.“
I'm not telling you something that you haven't already figured out but I would have used at least the minumum thickness that I would have used in steel. That would have been 1/4 wall steel tubing. I probably would have gone thicker with aluminum. I know aluminum is strong but it isn't stronger when you are using the same thinkness. The tongue is probably what gets the most stress on the trailer.
When I have my trailer built by my "Trailer Guy" as I call him, I always go over what materials he is using and usually go stronger on some items, never weaker. He has experience and engineered plans so I know I'm good to go.
I'm not quite understanding your question. We have 2 doors, and 2 basement access doors. One of each on each side of the trailer.[COLOR=#000000 said:luk4mud][/COLOR]
Question, it looks like you have one door and that to put in the outside access to basement storage would not allow for a second door (assuming I want to keep the height the same)?
^Jim, so your 5' walls are the key- 1' higher than a "normal" td. Thanks!
^Got it thanks. I gotta decide whether the extra foot in height is worth the space gain. Right now I am thinking that I don't want that trade off.
With 31" tires under my trailer, my trailer is going to be about 6' 8" at the roof, no taller than my Jeep. It may not be as bad as you think.
I am on 35's to match my Jeep. I want to make sure I stay in the slipstream of the Jeep if possible. I have no clue whether 4' completely keeps me there, but have less chance at 5'.
