the onboard air thread
Borrego60
Rendezvous Conspiracy
Air comp
I also run a Xtream outback compressor. I mounted it inside the frame rails,also mounted two air tanks. One tank above the spare tire in between the cross frames and one next to the compressor itself. I also mounted a solenoid to make sure power is cut off to the compressor so if air pressure drops the compressor does not come on without the truck running which would kill the battery. Nice little feature to have. I also have the same system that kills all power to my radios and related equipment when the truck is off.http://i162.photobucket.com
flipstick
