Status update..
I am sorry it has been a while since my last update but it always seems that when I have a deadline looming everyone and their grandmother either needs a favor from me or has some sort of event that I have to attend (i.e. birthday parties, bachelor parties, weddings, etc.) so I have only been able to do a couple of things on the Rover since my last update. Thankfully, today and tonight are open for me to me to get some work done and after the two birthday parties this week and my buddies wedding this weekend it looks like my schedule will clear up enough that I can really get down to business on the Rover.
Anyway, so the progress as it stands on the Rover right now. The driver’s side seat mounts are done, just waiting to be painted, but I will paint them when I patch the floors and paint/sound deaden the entire floor sometime early next week.
The rear seat structure is almost done, it would be done by now, but conveniently I ran out of welding gas and welding wire at the exact same time; combine that with my lack of time to buy more and further progress has come to a screeching halt for the last few days. I am buying more welding gas and wire today so that I can finish what is left of the welding on the rear seat structure tonight.
I did manage to fit the strip down and modifications of the 1995 RRC steering column in earlier this week. So now all that is left to do on that is wire it in and either fabricate a mount or find an original 1995 RRC steering column mount to fit it into the Rover.
Now for the info:
The rear seat structure has been very easy to do, especially when compared to the saga of lowering the front seat. It took me longer to figure out how to do it and then layout all the measurements than it has to actually fabricate the seat frame. If I didn’t run out of welding gas and wire I would say that the bulk of the work on the structure could be knocked out in a weekend. I think I have maybe five or six hours into the rear seat structure so far; which includes the design of it.
Maybe this is like “the calm before the storm” and things will become more difficult later on, but I was really expecting this to be much more difficult than it has been so far; its just been cutting, welding, and drilling. haha I guess that is why I haven’t taken too many pictures…it is sort of a “what you see is what you get” kind of a thing.
I laid out the rear seat structure the way I did partly because I had to and partly because I wanted it to be that way. By luck it would seem that all the floor supports and mountings somehow are in just the right place to tie in perfectly.
Let me explain. An original Range Rover Classic seat base/seat tracks have measurements of 12.5” front to back x 17.5” side to side. And whether by luck or by the “careful” planning of Land Rover, the distance from the front mounting structure for the original 60/40 rear bench seats to a floor support that runs the width between the wheel wells is roughly 12.5”. The benefits of having a floor support in that particular location means that I can tie the structure I am making into it instead of having to fabricate one of my own.
For those of you who don’t know, it is not really a safe idea to just drill some holes in a sheet metal floor and then through-bolt the seat frame directly to it, because in a car accident the seat could just tear through the sheet metal floor leaving the person sitting in that seat in a very bad and potentially dangerous situation. So when mounting a seat into a vehicle, always try to tie into as much structure as possible; especially when the seat belt mounts directly to the seat itself on both sides.
I am a big believer in looking at “overkill” as a good place to start. So I decided to tie into the original seat belt mounting holes as well, because those seat belt mounts are tied into mountings on the frame.
I am using 2” x .250” flat steel for everything but the leading edge of the rear seat structure, which is 1.5” x .250” flat steel.
So to recap, I am attaching the fabricated seat structure to the Rover in twelve locations that are located on three floor supports, one of which is tied directly into the frame. I am using zinc plated grade 8 bolts, washers, and nylock nuts for everything; and I might also beef up the original mountings as well.
