evomaki
Montero Gurus,
This is kind of a silly question, but given the option with a vehicle that has the timing assembly off and the rockers off, would you install the rockers back on first and then the timing assembly, or the timing assembly first and then the rockers? This could be one of those either or deals. Maybe there will be way too much spin in the camshafts w/o the rockers on. Anyhow, if one way is even 10% easier than the other, sign me up for the easier. After doing those valve stem seals, I'm ready for a lot of easier. That was a nerve wracking job, the kind that once you get good at it you never want to do again. I do know that the cam timing marks are on the valve covers, so for sure those would have to be placed back on temporarily if timing assembly done first before final on the rockers.
Also anyone by chance happen to know if/where the neutral position is on the bottom end such that one can rotate the timing assembly w/o hitting a piston. Many thanks,
