Tire Inflators - Which to get?
Scott Brady
Founder
Yeah, I weighed the unit. I am pretty anal about every pound now that my truck weighs as much as a duece and a half.
What is not included in the weight is wiring, relays, breakers and fittings. Not sure how much more that would add.
Jonathan Hanson
At least 30 pounds. So I was right all along.
Redline
Likes to Drive and Ride
Master Flow- Breathing Life Into An Old Thread
I wish I could say I found some of these Master Flow compressors for $25.00. I have been aware of these little, powerful compressors for a couple years but was not able to find them at my local Checker/Kragen Auto Parts chain when I looked.
The Extreme Aire compressor from Extreme Outback Products has been a part of our outback gear for a few years, a portable model mounted in a tool box. I like this pumper very much and have used it on several tires. However, the tool box mounted Extreme Aire is a heavy and relatively expensive compressor. I can't afford the space or money to have one in virtually every rig we own. With these Master Flows Q-Maxx compressors I can.
Last week I discovered the Master Flow Q-Maxx compressor at my local COSTCO for $49.00. I bought one and tested it, then bought a few more. One for each vehicle and/or spares. My motto, borrowed from Filson's, is "Might As Well Have The Best". But there is a strong case to be made for 'value'. With backups at the ready, I'm willing to put one of these to the test, maybe even hard mounting one in the engine compartment.
Tire Inflation Test Data March 2007
Temperature 50-degrees Fahrenheit
Elevation: 4,800-ft.
Tires: BFG 255/85R16 on an F350
Tires lowered to 15-psi, with a target inflation of about 50-psi. This is more than I usually run on these tires when unladen and close the my towing pounds-per-square-inch.
First Tire:
15 - 46-psi: 5-min, 2-sec. (gauge indicated 50-psi)
continued up to 54-psi: 6-min, 35-sec. (gauge approx. 60-psi)
Second Tire:
15 - 54-psi: Elapsed Time 13-min, O-sec.
Third Tire:
15 - 52.5-psi: Elapsed Time 19-min., 30-sec.
continued up to 56-psi: 20min., 30-sec.
Fourth Tire:
15 - 67-psi: Elapsed Time 30-min., 0-sec.
continued up to 97-psi (gauge indicated 105-psi): 40-min., 0-sec.
The compressor was turned off between tires just to reconnect the hose and once to move the battery claps (they're not long enough to reach the left-rear tire on a crew-cab F350). I stopped the clock while the compressor was not running. My test compressor did blow a fuse when turning it off and on onetime. It was replaced with the provided 30-amp spare (I threw a few more spares into the kit).
Forty minutes is the maximum recommend continuous run time for this compressor which I is why I just kept filling the last tire to work the pump and see how high it would go. Even if I needed to get my 255s up to 'loaded towing pressures' this little compressor will easily do it in less than 40-minutes; probably closer to 25-30-minutes. Surely it will run hotter during summer heat but it appears to have plenty of cushion to fill the tires on my rigs. Filling the tires of a whole trail ride group is another matter.
With this 'worse case' test scenario out of the way, when I'm out traveling off-highway and need to refill tires to hit the high speed pavement, 35-40-psi is usually plenty for my 32 and 33-inch tires.
My unit came in a handy carrying bag, and for $50.00 I think they are very worth the money. They are advertised on eBay for $80.00. This seems like a very good solution for an average user to inflate moderate sized tires.
redLine/James
Scenic WonderRunner said:
This summer......while in Stillwater, Minn. I found this SuperFlow MV50 at Checker Auto Parts. I came in off an ad they had.....they were out of that one but said they had a better one at the same price!.....I paid just $24.99 ;)
I've very happy with it!
Here is a Review I found........
....that's Not my hand!....hehe
navara-au
Damn that just looks like the TJM compressor I bought for $200 au (160 us$)
The only difference is mine has a metal tray, 7mtr rubber hose, air filter and a TJM sticker as well as a carry bag. Man those TJM stickers must be expensive:Wow1: .
Does the master flow do 72 ltr's (19 gal) per minute?
BTW Im happy with mine it certainly does the job.
Redline
I don't know how to measure liters/gallons per minute, the compressor output I'm familiar with is CFM (cubic feet per minute) but...
The review linked in the post I quoted, the second post in this very old thread, and have also pasted below, says that these compressors do put out 72 liters-per-minute.
http://www.gearinstalls.com/pepboys.htm
"72 liters per minute is 2.54 cfm."
Nonprophet
The ULTIMATE Tire Inflator!!!
If size, weight, and expense are your considerations (and they always are for true-blue explorer) then the ultimate back-country tire inflator is a simple DIY kit that costs about $20, weighs less than 3 lbs., stows very easily, and doesn't require a tank (infinite air supply), or any outside source of power (battery, electricity, etc.)
How can that be you ask???
:bike_rider:
I built a rig using 20' of coiled air hose with an inflator tip on one end, and a compression guage fitting on the other. All you do is pull one spark plug, screw in the adaptor end of the hose, start your engine, and VOILA 150-200 PSI for your tires, lockers, whatever.....!!!
It's cheap, simple, small, and it works every time........
NP
Nullifier
Well I have hte viair 460c. It has been totally reliable so far. It is not the fastest out their but for my tires it works great at 1.66 cfm. I am running a 105 pressure switch so i did not have to set up a seperate regulator for the arb lockers.
I looked at a lot of other higher performance options but doubling the cost and going as high as 4x the weight pulled me back from them. Some of those high performance compressor systems go 40#! Keep that in mind because keeping things light is a priority on our heavy rigs.
Redline
Yeah, that is an option, but I'm not sure I want to pull a spark plug on a dust covered engine every time I want to air-up. And doesn't work on diesels. I have been driving diesel pickups off-road for about the last 14-years, just recently started playing with smaller gas-powered rigs; a Jeep LJ and now a Toyota 4Runner.
:bike_rider:
NP
kcowyo
ExPo Original
Another vote here for the Super Flow MV-50. I picked up two of them almost 2 years ago when Checker's had them on a clearance sale.
I thought for the cost, a second one might be a good idea but the only problem I've had is one time when I put it back in the bag, I set the compressor on one of the clips and it crimped it. I straightened it back out and no problems. The second one is still new in the box, haven't needed it yet.
They're noisy little buggers but it airs up my 285's from 16PSI to 35PSI in about 4.5 mins per tire. Not as quick as CO2, but they're a good option. I also use it to air up my airbags and no overheating or blown fuses yet. Not bad for $25.
ntsqd
Heretic Car Camper
I too bought a couple of the MV's when they were being blown out by whomever had them. I've been impressed with them, especially considering the price. Ultimately both trucks will have OBA and these will fall back to back-up status. The Sub is IP with a std York set-up. Patch will get this once it's finished:
It's sort of an Oasis, only using a compressor larger than a York and driving it with a gear redux starter motor. Part of the experiment is to find out if the starter motor can handle shortish periods of near constant duty.
Ryanmb21
Master Flow from Costco
I just bought Master Flow Q-Maxx 12 volt comressor at Coscto for $50! The package appears to be high quality, it even came in a nice bag:exclaim:
I know it's a cheap answer.....but what do you all think? Will I run into any problems?
jim65wagon
Since that looks exactly like the MV-50, right down to the baggie the filter came in, I'd say "no problem" After a long hot day of slow speed, mine did six 33" tires before the overload kicked in and shut it down. If it wasn't mounted underhood I think it would've done all eight tires we needed to air up without any problems. Oh. and after the unit cooled down some it fired right back up.
CharlieGreenT
