Tire load range and pressures
Regcabguy
Oil eater.
I’m sure I didn’t ask the correct question.
Is it ok to run 35lbs of pressure in an E rated tire for daily driving on a F150? That’s the recommended pressure on the door jamb tag.
Absolutely. I don't know why manufacturers insist on supplying passenger car tires on LT trucks with some exceptions. The E's will be way stronger and more flat resistant.
AMTRV
An SL tire @ 35 psi carries more weight than an equal size E-rated @ 35 psi.
The best is to look up what your OEM tires carry @ 35 psi, then on Nitromethane's table, find an E-rated size that carries the same load @ 35 psi. You may have to upsize, which you plan on doing regardlesss.
I'd guess the 275/80R18 size, 2535 psi @ 35 psi, is a good fit.
Thanks Roy, but I’ve never seen that size. It does sound interesting though. I see Kendra makes one?
javajoe79
Fabricator
Probably because they’re completely adequate for most people plus they ride better. They’re not using a more expensive tire, just because.
billiebob
I’m probably going with a E rated tire because there are not many choices in a SL tire. Probably will go with 285/70 18. I had E rated 285/75 18s on all of my previous trucks because they were all Superdutys. Never had a problem with flats or cut sidewalls. This 1/2 ton changes everything. I want to keep the nice ride but also want to keep the strength needed to handle the rough trails that I encounter on almost every excursion.
Thanks for the above information. At least that answered my questions.
so capability, strength, all you need on an F150 is a C Rated tire. E Rated will be tougher and heavier, giving a less compliant, rougher ride, this is a fact of physics. Tire choice is always about compromise
every tire has a spec sheet on capacity, that is your best resource, pick the tire with the correct capacity, the decide if you want a tougher, rougher riding tire.
ps, more important than C/D/E Rating, is tire weight. Increase the unsprung weight exponentially creates a rougher ride. I went from C Rated 33x10.50R15s to D Rated 7.50R16s and lost 8# per tire even tho I went from C to D, The ride is exponentially smoother, And the gas milage increased from 17mpg to 22mpg. Compromise, guys laugh at my skinny tires but I no longer need to carry 5 gallons of extra gas. Pick the compromise important to you.
AZXPLOR
