Tongue Jack w/ Pneumatic Tire
dusty122
I don't think any jack dolly wheel rolls easy in sand, A little better on dirt. I found a 8"solid tire on aluminum wheel with ball bearings someplace and it works OK=brian
I went this same route. I got the biggest hard rubber castor from harbor freight i could get and bolted it on to the end of a jack. it works pretty well. the plastic wheels dont really work anywhere and the pnuematic ones id pop the tires or it just makes it tough to move. My only downside with doing it this way is that the jack is pretty tall and I cant lower the front of my trailer enough to get the jack airborne to remove if im not on a flat surface.
Kcdude
I swapped out to a drop leg jack with a stationary foot and a second foot with a RWM caster wheel....rolls with ease and I have a flat base option if needed. The swivel caster is urethane over iron, roller bearing, 2000lb capacity, purchased on closeout off Amazon for $40.
