counterbalance
'08 LR3 HSE owner here. I've read many times that weight distributing hitches (WDH) are not copacetic with the Land Rover's air suspension system. Basically, a WDH's want to mechanically level the trailer will "fight" with the Land Rover's auto leveling capabilities.
We used to have a fairly lightweight tent trailer with a WDH, and since I was none the wiser, used the WDH it came with. I had no issues, or at least none that I was aware of! We're upgrading to a heavier travel trailer, and I'm wondering if I should consider an anti-sway solution.
This is a great article: https://www.etrailer.com/faq-weightdistribution.aspx
It seems like most anti sway solutions are part of a WDH system. And an anti sway solution that is independent of a WDH is called Independent Friction Sway Control.
Finally, my question! Is there an independent anti-sway solution that other Land Rover owners here use?
Thanks in advance.
Thanks in advance.
