TRADE: 7.3 Excursion 4x4, Vegetable Oil Conversion
Where is the truck located? Unless I missed it.
Never mind. CB. Way up high. I'm showing this to a friend taking a job in Rocky MTN NP and she has a clean Forester.
Double_Eh
Sounds good, thanks!
Also, just to clarify- This excursion has two tanks and both can run on diesel just fine. The original, 45 gallon, stock location tank is heated and can run vegetable oil, diesel, or any combination of the two. There is also an auxiliary, 20 gallon, tank mounted between the frame rails that only runs diesel. Total of 65 gallons, giving roughly a 900 mile range when all full. The vegetable oil system is pretty transparent and can be ignored if/when you're not running vegetable oil.
