Trail capable teardrop trailer, 6x10 Benroy
Citylights
Broken spring, trail repair. Original axle and spring was rated for 2000 lb. Parts for permanent repair, 3500 lb axle and 2800 lb springs. (Trailer weight is 1800 lb loaded.)
RoTorKev
Wow! Great job! I would love to see some more pictures of the inside sleeping area. What would you estimate the total cost of the build is?
Citylights
Thanks for the kind comments.
I kept track of every nut, screw, piece of wood, and bottle of glue. The build was just over $4000, until I replaced the springs and axle. Now it is $4650.
Cost
$75 2x4 deck wood, screws, glue
$120 5000 btu air conditioner
$40 undercoat paint
$170 six sheets 3/4 plywood
$163 fantastic vent
$57 - 6' Galley Lid Hinge
$55 - one pair 1/8" Offset Door Hinges for 3/4" doors/walls
$60- two Inside/Outside Locking Door Latch/L-Handle sets, L&R
$17- one Locking Galley Lid Latch/T-Handle set, RS
$156 - two 12x18 Crank-out Windows
$50 construction adhesive, glue, electrical conduit and fittings
$100 longer trailer tongue
$25 more undercoat paint
$26 trailer hitch
$25 aluminum shore power receptacle
$ 17 under bed storage hardware, hinges and handles
$61 2x2 and 1x2 and 4x8x1/4 plywood
$43 1x2 and 4x8x1/4 plywood
$429 light fixtures, kitchen counter, drawer slides, wood siding
$273 cabinet, insulation, trailer lights, more glue
$123 wire, outlets, electrical boxes, GFCI
$235 paint, hardware, cabinet wood, more glue, laun skin
$120 battery charger and converter
$210 2 burner cook top, Coleman cooler
$23 more glue, 2 1x4x12 trim
$34 wood filler, screws, 2x2 lumber
$52 electrical plugs, clamps, outlets
$107 battery
$600 aluminum siding and angle
$200 specialty aluminum trim.
$200 hardware, hinges, stainless screws, butyl tape.
$500 trailer
$400 3500 lb axle and 2 1400 lb springs
$4650 Total
iStan814
