Trailer axle
SoDakSooner
They will be especially if you want the center caps on. May sure you get at least a 2" spacer, when you order the spacer make sure it has a large enough center hole to clear the trailer hub as well. I ordered Spider Trac spacers in a 5 on 4.5" flavor and they didn't clear. I have to have them machined out to work. Then they are only 1.25 or so and not thick enough to clear my center caps.
You might try a low profile bearing cap. May give you enough room.
Babbert
