Trailer mounted FWC electric connection
Dustman
How would one go about connecting a FWC that is mounted on a trailer to the tow vehicle's hitch wiring plug? To at least power the runnzing lights if not also charge the battery?
Stan@FourWheel
On most FWC's, the "white" wire coming out of the front would be the positive +
The black wire coming out of the front will be the negative -
Dustman
Thanks Stan. Do you know, if the trolling motor plug coming from the FWC is a two or three wire plug? I would like to rig up some kind of extension so I could plug the cable coming from the FWC into a four wire flat receptical on the bumper of my truck.
pawleyk
Running from Monday..
Ours, at least, was a 3 wire plug. One lead for the ground, the other for 12v+ charge line and the third a 12v+ for the running lights.
2016 Grandby
Deleman
