Trailer power - one BIG battery or two small ones?
Ludedude
If the battery has a reserve capacity rating instead of an amp hours rating, it's almost certainly a thin plate starting battery rather than a thick plate deep cycle battery.
That battery has an advertised amp hour rating.
Battery Type:Battery Group Size:31M
Battery Type:Temperate Zone:North or South
Battery Type:Transportation Type:Marine and recreational vehicle
Design & Construction:Container Material:polycarbonate/polyester
Dimensions:Height:9-1/2 in.
Dimensions:Length:13 in.
Dimensions:Width:6-4/5 in.
Power Configuration:Voltage:12.0
Power Ratings:Amp Hours At 20 Hour Rate:100
Power Ratings:Cold Cranking Amps (Cca At 0 Deg.F):1150
Power Ratings:Reserve Capacity (Rc):205 min.
Product Overview:Item Weight:75.0 lbs.
dwh
Tail-End Charlie
Yea. that part about the type being "marine and recreational" usually means that the plate thickness is somewhere in between "starting" (thin) and "deep cycle" (thick).
Any data on the depth of discharge vs. number of cycles life?
dwh
Tail-End Charlie
Sears doesn't specify it, but the battery is an Odyssey PC-2150. Maybe Odyssey provides that information on their site?
ETA: Yes they do. http://www.odysseybatteries.com/battery/pc2150.htm
Deep cycling capability: 400 at 80% DOD
If I read that right, it's 400 cycles at 80% discharge correct?
Yup, you got it. Now compare that to the cycles of a true deep cycle battery with thick plates. (I'd do it but my netbook battery is about to die.)
flipstick
