Trailer wheel studs
PSea
was thinking more about this. just because you add a hub adapter ring, doesn't necessarily mean your new rims are going to stick out more. it depends on the offsets of the rims. they may not stick out at all. just depends. you should compare the two rims to determine offset differences. good luck!
jwiereng
I recently installed the studs from currie enterprises. 12MM X 1.5 X .610 KNURL and oem Toyota nuts. Everything is a close fit, I do not imagine substantial loss of concentricity. Tires could be out of round more than the ‘error’ induced by this method of mounting the wheels. I'll keep a close watch on them for the first little while. check torque. At this time, I doubt a hubentric spacers is required.
Houie
