cjken
Question
I've been doing some work on my van (1995 7.3 4x4 ex-ambulance) lately to deal with a few issues.
Finished ball joints, steering box, and ujoints.
I notice some sticking in reverse.
Truck drives perfectly in forward.
Almost feels like brakes are on.
I recently did rear brake shoes (drums)
I thought maybe something was binding in drums. But that is not the case. I pulled the drums and ran truck on blocks binding in reverse still an issue.
So I pulled drive shaft. Everything behind driveshaft moves freely by hand.
In front of driveshaft that is not the case.
I can manually rotate driveshaft (in neutral) in the forward direction. Trying to rotate it the other way can be done but is difficult.
With motor running in drive transfer case output shaft spins freely in reverse it requires some gas pedal pressure to get output shaft to spin.
Any ideas or advice to narrow this issue down. Anything I should be checking that I am missing??
Thanks
Thanks
