Here's a trick I've used a couple times to bring back a battery previously thought to not be able to be charged.
Most battery chargers in the last 10 years have a safety feature that will make it so it will not charge a battery that has a voltage under about 10 volts. If you take a pair of jumper cables and connect a good battery to the bad battery in parallel (+ to +, - to -) and then connect the charger to the good battery, it will trick the charger into seeing a good voltage, and charge both batteries. Once the bad battery has a voltage above 10 volts the battery charger will charge it properly.
I have also heard if you have a recently discharged battery, you may be able to get one last start (to get you to the nearest auto store to buy a battery) by adding half an aspirin to each cell. This has to do with the chemical properties of the aspirin combining with the sulfuric acid of the battery.
So ya guys know of any other tricks that may help an old battery?
