Chris,
Hope this is ok to post here..
Searching for my donor axles, “local” yard has two 2003, one in 3.73 and one in 4.10.
trying to spread cost out so I was planning to just refresh the axles and not regear right away.
van is 03’ 7.3l, plan is 6” on 35’s. main use will be highway trips towing 5k# camper.
I’m assuming I would be better off with the 4.10? Asking because I see a lot of the builds using 4.56/4.88, seems high but I’m new to this.
Thanks in advance
Okay sounds good. I’ve read that your kit works with the 99-04’ f250/350 front Dana60 but that you use the 02-04’ for the axles you build. What is the advantage to those years?
Looks like some great rigs in those shots. Also a great time.Both van camps this fall were WET! That's the gamble we take! Still had a great time and so did the kids.
We stick to the 02-04s because they're all Dana 60s. From 99-01 everything is a Dana 50 unless it was under a DRW truck. Most yards only specify it as an "axle" so the price is usually the same. D50s are actually more $$ to build too.
