Unimogadventures - Our build and travel thread
Iain_U1250
Great build vid. Where was this pic taken? Looks like a great spot off the beaten track. Has Covid hampered your travels or are you still mobile? Cheers.
Hi SImon, the photo was taken at James Price Point. It was great, saw three cars in the week we were there. Covid sure has had an impact, especially when they can close the borders overnight. We are planning another Australia trip for later this year, just need to find someone to look after the cats.
PKDreamers
Hi Bundjalung Nat park is our favorite camp site we Love it , great walks , swims , rides etc etc. We have been going there for the last 15 years or so.
You camped one camp site down where we normally camp.
PKDreamers
Camp site 7 or 8 summer and then 46 if they are taken.
It is also great place to watch fighters do their bombing runs. We would love to be there when they do their live firing when the government can afford the ammo lol lol.
Iain_U1250
We have decided to make a new awning system for the truck. We have in the past had shade cloth that attaches to the roof bars, a heavy duty tarp for when it's wet. This time we are going to use canvas and something similar to what you get on caravans. This is what we currently have, and it works OK, but shadecloth is not really that good at keeping the heat out, and the tarp is pretty heavy. All up the whole awning and sidewalls should be about 22kg, so about the same as what we carry now, but it should look and work a lot better.
We will also have side walls, that attach via zips. We will have two side walls, that can also attach to the front. The awning will be 4.7m wide across the truck, and 4m away from the truck. We will incorporate some windows into the sidewalls, just normal mesh. The whole thing won't be much use for keeping bugs and flies out, as they will just be able to get in from under the truck.
The awning will attach to the camper via sailtrack. This should make it more waterproof. The best place for me to attach the sailtrack will be to the roof gutter. The gutter is stuck on with Sikaflex 252, and I decided to to the same way with the sailtrack. First was the clean, rough sand and then prime with the Sika-206 G+P primer to the two pack epoxy paint that;s on the gutter. The primer is necessary and works great, not so easy to apply, as you have to do it very quickly when it is hot like it was today. It also runs like water, and can get under the masking tape if it is not stuck down.
Primer goes off in about 10 minutes, and then you have to stick the SIkaflex-252, which is terrible stuff, it goes everywhere, hence the masking tape. .
Once the sailtrack was on, I pulled off the masking tape to prevent it getting stuck in the Sikaflex.
The clamps keep it held in, the are pretty loose in face, as I don't want to squeeze the Sikaflex out, the minimum thickness is 3mm, or the Sikaflex will not be that strong.
As you can see here, Sikaflex and the red outback dust love each other, and it is very difficult to remove. I'll be covering the Sikaflex with some white silicone, that seems to repel the dust not stick to it.
I did add a stainless steel bolt each end of the sailtrack to provide a mechanical lock as well, hopefully they will not be needed, but more of a "just in case"
We have a roll of canvas; 40m of it. We will be able to do all what we want and have quite a bit spare.
This is what we bought. https://www.paskal.com.au/razorback-12-ripstop.html In the light grey colour.
Iain_U1250
Trish now has to figure out how to make two seams to join three strips of 4m x 2m wide material together with a "Full flat felled seam" like in this video.
We will make a video of it, it's going to be quite an undertaking working with that amount of material.
Iain_U1250
This is the awning as it is today, 157537125_1377223979277233_4570844671000103504_o.jpg
It took fair bit of effort, as it is quite big; 3.5m x 5m. We had to move bit of furniture to get it to fit in the lounge and dining room
The double sided "basting tape" worked a treat, holding the seams together.
Getting the large runs of material to fit under the little Singer sewing maching took some figuring
We had to build a runway from all our various camping tables to do the long runs, especially the zips.
And it needed a fair bit of rolling up to fit under the arm of the machine, a proper industrial machine would have made it easier, but the Singer worked and only cost us $199 a couple of years ago.
In the end it worked out great.
Probably the hardest part was the zip for the hatch in the awning so I can still climb up and down the ladder.
We still have to make the sides and the front, hoping they will be a lot easier as they are smaller, but there is a lot of fiddly bits, as we want a door in the front and one side, and mesh windows in all three sides.
It is quite easy to put up, the first time took us about 10 minutes, but we should get faster and doing it on concrete didn't help things either.
We have a few more things to do to this part of the awning, like fitting the clips that will hold the rear corner tight, and the clips on the front bar to hold the front of the awning taught.
All in all, it has turned out pretty good we think.
sAsLEX
Wow that looks great!
The vortex generators confused me for a bit as I thought they were part of the attachment system for the walls!
Iain_U1250
that thing is huge, its going to be a nice retreat on sunny days, awesome work.
Did you build a shed for the Mog?
That was the plan, we have been in some very hot campgrounds and got tired of using a various tarps and shade cloths to create some shade. This should be a lot better, we will find out how well it works next week when we take it out for it's first real test.
Shed was there before Mog, just needed to make the door a lot bigger, it used to be our photography studio.
Wyuna
Yeah i noticed you guys like the heat from your travels, it'll make a huge difference from direct sun.
We are the opposite, we love the cold, we are leaving bris for Vic highlands via the snowy today for a month of exploring before we come back and head back to the NT when it cools down.
I find having a shed in brisbane over summer is well worth it, i've lost a few cars due to hail over summer when they haven't been under cover
WonaWarrior
