Unstuck my transfer case shifter......
High Center
Then went on a 3 day motorcycle ride to the mountains. Got in the Disco this evening to continue my worklist. Stuck again.
3 days....
Console removal....x2...
"These are the days that try men's souls."
Howski
This is in my future on my Disco ii as well. I assume it is a royal pain. Did you remove the solenoid as well?
High Center
I didn't. I opted for the "take the console off and soak the shifter box in penetrating fluid then pry, pry, pry" It worked but took a while. This evening as I was moving the disco into the garage to begin surgery, I was able to move the shifter again. Thank God.
In all honesty the console job isn't so bad. The second time would have gone much quicker.
JSBriggs
What do you mean stuck? Diff lock or high/low? If high/low its most likely the solenoid. Pull it and seal it back up. If diff lock, the it might be the switch, look in the manual on the adjustment procedure.
-Jeff
getlost4x4
REMOVE THE SOLENOID. No more stuck T-Case. I did it to mine a few months ago. Makes life so much less stressful.. One less part that can break.
Mitch Bears
