heeltoe989
Fellow Canuks
I wanted to let you know that Toyota Canada is giving me quite a problem with my TRD Supercharger I got from Shannon at Champion Toyota. I was planning on doing the install myself because the dealer up here won't do it. Apparently the TRD Supercharger has been discontinued in Canada which means if you bolt on the US charger Toyota Canada will void your warranty.
The only reason I really need the dealer is to do the ecu flash which is required by the manual that came with the charger. I'm currently trying to find a dealer that will do the ECU flash but I'm having trouble. No dealer will touch me for the flash because the charger has been discontinued it makes the liable if something goes wrong. I said I would sign a waver but that didn't seem to get me anywhere.
I'm currently trying to find a friend that knows a good Toyota mechanic, that might be willing to do the Flash under the table an off hour type thing.
Thought you guys should know.
Wish me luck.
Richard
Wish me luck.
Richard
