Dave in AZ
Truckbed Inverter use to supply a Power Station, and video. Applicable to Tune M1, OVRLND, and other canopy or wedge campers for an easy power recharge option.
Was msging with someone today about 3rd gen Tacoma, power stations, and how to use the truckbed inverter to supply one. I know several other trucks have an inverter this would apply to, such as F150s.
If you have an existing truckbed inverter in your model, you can make use of your alternator supply, and completely remove the need to get an alternator dc to dc converter, to isolate your start and house batteries, to limit current draw to avoid alternator damage, and to run thick 8AWG or 10 AWG cables from alternator to truckbed. You end up with a nice prebuilt alternator power supply, isolated from starter battery, ready to go.
Here is a video I made, showing the issues involved, and a quick solution and success.
Video shows using the 3rd generation Tacoma truckbed 120v outlet, to charge a Pecron e1500LFP power station. The problem with Tacoma power is that it is a Modified Sine Wave (terrible), not a Pure Sine Wave inverter. No power station tested so far (that doesn't have an external charge brick!) will accept the poor malformed ac power, including Pecron e1500LFP, Bluetti AC200Max, Ecoflow Delta2 Max, and Jackery. So you can't just plug your power station into the AC and charge it, you have to somehow convert that nasty power to something your power station will take, which means some dc voltage and feed it into a Solar Charge Controller port.
