Vector OffRoad
Supporting Sponsor
Proudly Made in the U.S.A. $349.99
https://vectoroffroad.com/products/jk-highland-platform
The Vector Offroad JK Highland Platform practically doubles the use-able space in the rear cargo area. It's a must for overlanding, campers, or serious grocery getters! This high strength solution is a perfect place to put camping gear for your next adventure.
The JK Highland provides the following benefits:
Mounting hole patterns cut into the platform for RotoPax Water/Fuel/Storage mounts. The platform can hold up to two 4-gallon RotoPax containers on the underside of the deck.
High Strength Steel Construction, weight tested to 230 lbs without failure.
Bolt-on installation, requires no permanent modifications to the vehicle.
Standard finish - black wrinkle powder coat.
Multiple lashing points for straps and/or cargo nets.
Included quick release wing nut set allows easy removal of the main platform deck without the use of tools. Wing nuts allow for quick removal if you need to transport large items in the back of your rig from time to time.
Approximately 24 1/2" clearance from the floor to the bottom of the platform.
Fits: 2007-Current Jeep Wrangler 4 door Hard Top or No Top only
**Product images may display optional accessories, configurations, or finishes. The actual product may vary slightly from what is shown. If you have any questions regarding what is included with a product, please contact us.
***As with all of our products the JK Highland Platform is designed for off-road use only, compatibility with OEM systems has not been formally tested.
