vehicles on CraigsList in Las Vegas
haven
89 Isuzu Amigo 4x4 $1200
POSTING DELETED
1989 Isuzu Amigo 4x4 $1200
looks like a fun truck for the money
probably a 4 cylinder engine
Wander
I'm pretty sure the top is removable on the Int'l- not positive but I'm pretty sure I've seen these as fully open vehicles.
haven
78 Jeep J10 pickup $1500
http://lasvegas.craigslist.org/cto/1254105751.html
1978 Jeep J-10 shortbed pickup $1500
360 V8, GM TH400 automatic 3 speed transmission
Borg-Warner QuadraTrac full time 4WD, 2.57:1 low range
Dana 44 axles front and rear, manual diff lock
spring over axle conversion in front, 5 inch blocks in rear
new ignition system, fuel pump, starter, radiator, and motor mounts.
new shocks, new tie rods, new pittman arm with 4 inch drop
ProComp alloy wheels, Mud Terrain tires
"Starts, runs, and drives great!"
haven
97 Ford Ranger 4x4 $2700
POST DELETED BY OWNER
1997 Ford Ranger XLT pickup
5 speed manual trans, 4x4, 5sp,
A/C, new tires and shocks.
"Always maintained"
nothing special here, would probably make
a good work truck
haven
85 Chev 2500 4x4 pickup $1000
1985 Chevrolet 2500 3/4 ton pickup
4x4, long pickup bed
no information about engine or transmission
new starter, new alternator, new battery,
a flowmaster exaust, new air filter, new fuel filter
both gas tanks are functional and gauges work
runs fine...a/c doesn't work
haven
91 Ford F150 Lariat 4x4 $1700
POST DELETED BY AUTHOR
1991 Ford F150 pickup
6 cylinder engine, manual trans, 4x4
Lariat trim package
recent tuneup, new clutch, new radiator
recent water pump, fuel pump, fuel selector valve, fuel filter,
fuel pressure regulator, fuel relay, oxygen sensor, MAP sensor,
air charge sensor, voltage regulator, colant temp sensor
(sounds like this vehicle recently had trouble passing smog inspection)
You could drive this vehicle anywhere in Mexico and Central America
without attracting attention.
haven
89 Jeep Comanche project $2700
1989 Jeep Comanche pickup $2700
new 6 cylinder motor installed in 2004
transmisson and transfer case from a 1999 cherokee
front end and doors from a 1999 Cherokee
6 inch lift with brand new 31x10.5x15 mud terrain tires
95% complete.
haven
99 F250 5.4 V8 powered by CNG $2800
1999 Ford F250 pickup
75,000 miles $2800
5.4L V8, automatic trans
bench seat
factory modified to run only on compressed natural gas CNG
extra large bed mounted gas storage tank
first owner was City of Las Vegas
all scheduled maintenance performed on time
my comments:
the advantages of CNG are lower cost per gallon equivalent
and very low emissions
the disadvantages include fewer miles per gallon equivalent
than gasoline when driving in the city, and very few filling stations
Putting the CNG storage tank in the truck bed decreases
cargo capacity.
CNG provides about 75% of the power that gasoline does,
or about 200 hp in this application. Acceleration is slower
than a gasoline V8, but is adequate.
CNG costs about $1.95 a gallon equivalent in Las Vegas.
The price in your location may be a lot more or a lot less.
Each state has a different plan to tax CNG sales. Some
states give a credit when licensing a CNG vehicle.
CNG is currently sold to the public at 7 locations. See the map
http://www.lasvegascleancities.org/alt_natural.html
Fuel economy is about 15 miles per gallon equivalent. The in-bed
tank provides a range of about 175 miles
CNG is very clean-burning, which reduces contamination
of the engine oil and accumulation of gunk in the combustion
chamber. Ford modified the engine to increase durability.
DanoWall
