It's Land Cruisers all the way down.
:xxrotflma
Don't you wish it had been a bunch of these?
http://www.turtleexpedition.com/images/t534.jpg
With all the Land Cruisers strapped together there's a lot of brakes/drivetrains/weight to absorb the pull on the Man. The winch mountings on the front two have to be absorbing a lot of strain.
If I had to criticise what appears to be a pretty professional recovery (esp given the number of people involved!), that would be it. I would have positioned the two winch vehicles as far back as possible, with three anchor vehicles alongside (i.e. five vehicles ranked close together).
Then the cable from the first Winch-truck would run around Snatchblock #1 on the Unicat, back to a snatchblock on Anchor-truck "A", back to Snatchblock #2 on the Unicat, and then terminate on Anchor-truck "B". The cable from the second Winch-truck would run around Snatchblock #3 on the Unicat, and terminate on Anchor-truck "C".
That way, each of the five trucks in the rank would only be taking a 1 x winch pull, except Anchor-truck "A", which would be taking a 2 x pull. Additional anchor trucks could be attached to the back of the Winch and Anchor trucks as necessary.
There are a few reason why I think this is a better way of rigging. Firstly, to avoid the problem mentioned above: the winch mountings were taking very large strains - of the order of 4 x winch pull in the case of the first winch truck. Secondly, because the winch mountings held, the winch-truck's frame was being stretched between the winch and the multiple anchors behind it, also with a 4 x winch pull. Thirdly, because the rigging between the achor truck and the winch truck is taking unnecessary strain (there's little reason to daisy-chain the anchors when they could be anchoring independently, alongside each other, unless the ground is very slippery).
Congratulations to the team, though - that sort of situation needs a huge amount of co-operation, especially if there is no clear chain of command. I bet everyone wanted to do it
their way!
(Interesting to see that this was a group of old ballies in the Toyotas! Spike will understand the term
