Volvo C304 (4x4) Restore and fitout - WR7002
Anthony.V
Wow! Quite the journey! Sub'd to this and Volvo 2.
Looks like Volvo 1 is on the home stretch. Hang in there! Can't wait to this see this thing out tackling the terrain. It sure has come a LONG way since day 1!!
Sent from my SM-G965U using Tapatalk
geckoadventure
Geckoadventure
Volvo 1 is coming home to Kuala Lumpur will be sometime after 1st September as I am away the next 2 weekends with the kids kayaking adventure. So Volvo 1/2/4 will all be in the same workshop. and I will finish 1 first then 2 and then 4.
geckoadventure
Geckoadventure
Tuesday 28 August 2018
Got 3 pictures sent to me.
The wiper arms and brackets are finally installed
And the dash is starting to look completed
What's left before it's sent the 190k to Kuala Lumpur on the flatbed:
Bleed clutch again
Brakes redo the rear piping
Fill/check all oil levels in everything
Finish air conditioning (KL job)
Wiring is almost finished so internal panels can be installed
Windows installed
Wiper arms/blades
Install doors.
They say 1-2 weeks before is ready to come home finally.
geckoadventure
Geckoadventure
Thursday 20 August 2018
Got a set of pictures sent to me of progress.
Headlights back in.
It's up on the hoist so they are working on it.
Work on the wiring continues.
The maze of wiring looks not so much of a maze and now looks connected up.
The interior lights etc and batteries are connected.
The dash panel is now almost completed and the water temp etc all connected and working.
Tacho and Speedo connected and warning lights etc connected.
Progress is being made. Today the wiper arms etc are supposed to be connected I guess then the windows can be installed.
I hope to collect it on 29 September and bring it to KL.
geckoadventure
Geckoadventure
Saturday 29 September 2018
Quick trip to IPOH 190k away to drop the kids home kayak trailer in for surgery after someone got the gap between the racks wrong and also fit 4 wheel disc brakes to it.
So what's been done to the Volvo quite a lot:
-Window washer 15litre made and ready to fit sits where the radiator used to go.
-Fuel pump wiring relaid to avoid andthing trouching them.
-Both forward winch cables are not enclosed in a tube for most of the underneath to stop any cable drag and protect all engine underneath delicate areas.
-All wiring is completed and we tested everything yesterday
-New fanbelt tensioner made and fitted
-Compressors etc work.
-Engine starts and runs nicely but very noisy I will assume that will change once its outside and all covers are on.
-Fan being installed to haul air over the turbo when its idling to stop radiant heat
-All the cabin panels are installed
-Window wipers work
-Rear camera up and running
-lockers work etc
What's left to do before it returns to Kuala Lumpur:
-CLutch test
-Brakes test
-PTO to be made running with new vaccum switches
-WARN winch to be tested
-Cable for Factory PTO to fitted
-Bolt down the dash
-Prime the aircond
-Check the radiator cycles properly
-Fit the rear internal lights
-Install the turbo fan
-Test the odometer
-Test the tacho
-Install the seats
-Fit the doors
-Fit the front windows
-Fit the rear seats
Whats to do when its back in Kuala Lumpur:
-Inspection and re-Registration
-Get interior panels made up for the centre console
-Fix 18500lb winch
-Road test
-Repaint to the new colour since the current colour holds oil stains/dirt etc.
-Get it ready for it's income making role.
They think it will be finished 5 Oct 2018 but we may leave it there for another week of testing.
Side views not much to see
The 2 colour interior lights work
Slowly its getting complete - right view
Front view
It's so close its quite exciting.
geckoadventure
Geckoadventure
Friday 5 October 2018
Late night pics I guess they were working on the lights.
Next weeks work:
-CLutch test
-Brakes test
-Install the seats
-Fit the doors
-Prime the aircond
-Install the turbo cooling fan
-Test the odometer
-Test the tacho
-Fit the rear seats
-Cable for Factory PTO to be fitted
-Cable for Warn Winch to be fitted
-Fix 18500lb winch
-Road test
Lights all done.
geckoadventure
Geckoadventure
6 October 2018
After collecting new winch cables for Volvo1 and the new fridge from the shop it was time for lunch then work on Volvoo 2 for the afternoon.
Work is held up on Volvo 2 engine mounts due to the unexpected Pinzgauer engine rebuild going on on the restored Pinz. 2 people took the engine apart and then got removed from the workshop so the poor workshop owner is trying to put it all together after balncing the pistons and conrods. This truck needs to be finished to give Volvo 1 a bay when it's transported from IPOH to Kuala Lumpur in the coming weeks.
Meantime we decided to work on the new doors and sanded them down ready for primer and tapped all the dents out from the tranhsporting from Sweden to Malaysia.
All was ok until breakfast decided to upset my stomach sigh.
The engine mounts look like they are getting closer to being completed however then the other PINZ decided to spit all its oil out the dipstick on startup in the afternoon. Oops another rebuild needed more delays to Volvo 2.
geckoadventure
Geckoadventure
Friday 9 October 2018
A fleeting visit to have a discussion on progress and what's left to do before I take it home. Home date is agreed now 17th October 2018. The Tow truck is booked and confirmed.
It rained the whole 190k up to Ipoh and the whole way back to KL. The drive back listening to Sting, Pink Floyd and Fleetwood Mac made the drive easier.
So progress since my last visit such a long time ago. They have finished the mods to the Orphanage's Kayak Trailer it's also ready to come home next week also.
A lot of little fixes and mods have been done, Fuel pressure issue has been resolved and the fuel filter moved to give more room for access. Air Tank moved also for more access to the engine bay.
The tube made and fitted under the chassis to allow the winch cable to not catch on anything is made and installed.
The rear side view and the new quick release tow bar for the kayak trailer all fitted
Brett smiling as he tells me it can go next weekend and holding the remote for the interior coloured lights. The rear tire carriers have also had the studs welded on now and not pressed in.
The front view and yes the doors are on for the first time in 7 years. Only the top halves to be fitted now.
Grills fitted on top of the rollcage to protect the radiator and air conditioning.
Everything almost fitted in the interior one seat and the gearbox cover to go. Leaving only the covering of the tunnel to be done and some minor painting of black around the window.
I hear I'm going to have a big issue at road transport inspection as I have changed the interior layout and also lined the cabin sigh! We will find out on the day.
The interior looks pretty good. The steering column cover is still to be found else they will have to fabricate an alloy one.
I can see all the instruments from my seating position.
The console looks good. Everything works except the 18500lb winch and the 2 air cond switches need to be fitted.
Right side view. The issue with the bottom of the poor gap at the bottom of the drivers door to be fixed in KL.
The lights in the rear 2 colours and the new black handles for climbing into the rear.
Green lights
Still one side panel to fit and the tree deflector is fitted to the top of the rear cabin.
View as the CIA satellite will see it lol.
View as the monkeys in trees will see it in Malaysia.
Yes it drives. Clutch pedal had the pivot point changed to make it work. Apparently it's a very heavy clutch, I will need to install the Toyota spring assist kit to fix this. They drove it out in the workshop but there is no brakes they ned to replace the vaccum pump as it's leaking and the air conditioning the shop needs a "new" fitting to prime the air cond.
So 8 days and it's home couldn't be happier. We have a small water leak to deal with at the water pump. Then I try and get inspection done the following week since everything that's needed to work for inspection works.
Still to do before next Saturday mooring. Steering Column cover. Fit floor. Fit PTO winch vaccum switches and panel. fit the door tops. fit the front window and the window wipers and washers. Fit door handles.
geckoadventure
Geckoadventure
Saturday 27 October 2018
5.55AM my chauffer arrives and I give him the keys to the 80 Series Landcruiser I'm borrowing/buying while my Isuzu is in the workshop for new master cylinder for the past 2 weeks. The aircond dies lol its a hot trip up.
Biggest day in the life of the Volvo it's coming home the tow truck is due to arrive in IPOH 9am, The 190k cruises past as my chauffer wheels his way north.
I say hello and goodbye to the all restaurant staff whom I've eaten breakfast at for the past 2.5 years.
Inspection time Brett and myself inspect whats done whats good and whats left to do.
Bolted all up for the first time its starting to take shape with only the transmission tunnel and the
repaint the obvious stuff to complete.
Pensive as I look it all over will it make the 24th November deadline.
The roof console and the reverse camera.
The harness seatbelts remain to be bolted in and the engine cover is finally bolted down.
The fuel pump and fuel tank filler area is cleaner with the fuel filter and compressor tank moved tight to the cabin. The fuel feed issue fixed with the minor leak repaired.
Planning the next vehicle? Or discussing RFC next event they are both going to attend.
Number plates now attached and the Kayak trailer tow bar is fitted. The rear panels all bolted in we found a water leak at the end of the journey.
Spare tires all mounted we need to mount a anti vibration rack later and a wheel mounting slide/guide pin.
The newly powdercoated grill and the tool kit is now bolted down behind the drill. The new front windows were only fitted Friday afternoon.
The moment for it to be squeezed onto the flatbed it fitted by inches.
The journey home uneventful apart from the tow truck struggling up every hill.
Pic of it in it's new home tonight. I took it for a drive before parking it in it's new bay while we finish it. Very night drives quite well apart from the shuddering steering which we think we know whats causing this.
Smudge12
