Here is the coolant filter mount that I made. Thanks to djbonsu for sending me a pic of a very similar one. I usually overbuild things (gross understatement!), but lately I've been working with strong lightweight products like aluminum. It is all about the design and where you put the bends for strength. This one is made from fairly thin sheet stock that I had laying around. Maybe a 1/4 lb. total. It mounts in all factory bolt locations. It's been on there for maybe 6 months and works great. There are 1/2" wide strips of adhesive weatherstripping between the aluminum and the PS reservoir.
I forgot to post a pic of the Autometer gauges I added previously. I wasn't sure that I wanted pillar gauges at first. Once they were in I loved them. The triple pillar mount doesn't interfere with using the sun visor. I also darkened the bulbs with a sharpie and kept testing brightness. Bright interior lights make long night drives difficult so they are just bright enough that I can see them. I know most diesel owners go with pyrometer, transmission temp, and boost, but fuel pressure is way more important to me. I previously had a diesel rated schrader valve and adapter (from dieselOrings). That is fine for occasionally hooking up a FP gauge but difficult to test pressure under load. The van factor requires you to at least disassemble a few things to get to the bowl. I wanted to see pressure constantly so I can watch for filter restrictions, any sudden drops, etc.
I also have all kinds of gauges and configurations on a dedicated tablet with Torque Pro. I use them mostly for testing and diagnostics but they are fun to watch on solo road trips. I found a slow oil leak today coming from my Diesel Site HPX oil crossover. Tried to tighten it some but made it leak a-lot. I didn't really like how it was made from the start so I'll be ordering the solid tube stainless HPX from RiffRaff tomorrow. Made in USA too. I will let you know how I like it after it goes in!
