elmo_4_vt
So it looks like it uses a relatively standard torsion spring setup. Have you thought about just buying a new axle with the correct track width so you don't have to run spacers and get it with a softer spring? If you get the weight of your trailer loaded as it sits now, it should be pretty easy from someplace like Dexter, Redneck trailer supply, or any local RV place. They will usually even come with the frame mounts already welded into place, so asside from maybe having to drill holes to make the frame holes, it should be bolt on.
Don
Don
