Warn VR Winches starting at $399*
flyingwil
Which one do you recommend for a fitted FJ Cruiser. ARB/ winch, RTT, OME, Fridge, full load??
yeah great question, which do you recomend for a 2010 frontier with arb bumper?
The rule-of-thumb minimum is to take your GVW (that’s Gross Vehicle Weight, not curb weight) and multiply it by 1.5. But this minimum rating is just that, a minimum. Certain factors can quickly cause your winch capacity to be exceeded so you need to think about your intended usage. Be aware that certain terrains and situations can put a much greater demand on a winch over the typical 1.5 multiplication rule of thumb. For instance a common cause for winching is mud. Mud however has an incredible suction force on a stuck vehicle and in many cases that 1.5 rule of thumb is far inadequate. Steep hills and frequent winching also put great demand on an electric winch. Understanding the purpose and safe use of winch accessories such as a snatch block can be invaluable when you need it most
In both the cases above, the VR8000 is close to the min, but if you can afforrd the VR10000 that would be the way to go.
Ramjet
Thank you, Will. I have order mine and will be installing it next week. You guys rock. That's why I went with a Warn. Only the best for me and the family.
CLynn85
Seems to be a common trend of manufacturers dumbing down their old models as entry level pieces. Seems like a great plan to me. Where are these built, USA?
Ramjet
Yep, good ole USA, Oregon to be exact. I just bought the VR8000 for my FJ.:wings:
iStan814
