water pump for Triton shower
cr500taco
I am going to be getting the Triton shower and was looking at the specs for the water pump recommendations. They recommend a range from .5 gpm - 1.5 gpm. The slower the flow the hotter the water can get. Just wondering what size pumps you guys are using with the shower?
Sent from my SM-T800 using Tapatalk
cr500taco
I have an L5 whats very similar to your Triton, suggest getting as large pump as practical. If you find consuming too much water, you can always throttle down heaters input. Just be careful, low flows can get water too hot very fast. Then the occasions you have unlimited supply its nice to crank up the flow.
At my cabin I will use its L5. Throttle down its nozzle water will get very hot & at good pressure. Its handy to wash down inside the shower/outhouse. Being naturally damp inside It attracts bugs & snails during the times I am gone. That near boiling spray quickly sweeps away everything.
Cool, thanks for your input.
vertical.dan
