articulate
I think this is an odd little device, but clever at the same time. Called the Hydra (made by Rompalicious), it's essentially a water bladder that's designed to attach to your driver or passenger seats.
I'm used to packing a 20 liter Scepter water can for filling one-liter Nalgenes throughout the day, and it works fine. I'm going to try this bladder style system for awhile, though, and perhaps use it as a supplemental water source.
It holds 2.5 gallons, uses ballistic nylon, heavy duty zippers, and nylon webbing. It also comes with two hoses, one with a bite valve with a holding magnet, and one with a drain valve.
Bonus usage: It was developed by a "Jeep guy" so it also secures around the side roll bar(s) in the back:
Some other cool details about it: the bladder is made by Nalgene, so it's antimicrobial and puncture resistant. The attachment for the hose uses a very slick quick connect, so you can swap the hoses easily and while the bladder is full of water without losing any.
I didn't verify this yet, but I believe the whole contraption is made in the U.S.A.
Anyway, I picked up two of these Hydras and have been using them for a few weeks . . . here are some photos for you.
The uber-nice quality bladder/reservoir, shown with the drain hose attached:
The quick connect:
You can get a good glimpse of the heavy ballistic nylon, straps, and zippers:
What's cool about the drain hose is that you can take advantage of gravity and use it for general dispensing:
What are your thoughts? How does this idea strike you?
The quick connect:
