We need a Unisolar hack
Discovery76
The last step is to solder 4 wires to the 4 spots I had exposed and simply connect the dots. I also epoxied the back on the exposed area to help secure the wires and seal up the exposed electrical connections.[/QUOTE]
Can you explain what you mean by "simply connect the dots"? When I expose the 4 spots with the dremmel tool, do I use wire to connect all 4 spots together? How did you connect a positive wire and negative wire to connect to your battery? Are the two metal tabs on one side connected together to form a positive wire and the two metal tabs on the other side connected together to make a negative wire?
I know this is simple, I just don't quite under stand how it works.
Thanks!
Dave
flipstick
