WeBoost Antenna mounting options for 3rd gen Tundra (2022+)
overl4nder
I want to locate the weboost antenna to the front fender, however most brackets I find are for Tacomas or Lexus. Does any clamp/bracket exist for the 2022+ Tundra with an antenna mount?
kidphc
Most fender mount brackets are simple bent mild steel.
Here is nmo one.
I thought they use the cb type of screw for the mounting.
For my landcruiser. I was able to find ditch light mounts that antenna mount extension options.
Sent from my SM-S901U using Tapatalk
kidphc
Something like this.
With the optional piece. Might work well.
It just will be closer to the a pillar. Unless you fabricate something up
WonaWarrior
