winmag4582001
I installed the kit in my driveway back in December using only hand tools. Friend welded the radius arm brackets on for me. Overall the kit is very easy to install, it's just nuts and bolts. You will need two big jacks and two tall jack stands. Other than that, it's just basic tools. I already had 2.5 degree camber/caster pills in it. The alignment shop ended up going with a 2.75 degree on the passenger side and used the 2.5 on the driver's side. Overall cost was $2750 for the kit with shipping and returning the factory I-beams. Got the rims off of ebay for $375, tires from ebay were $575 and the spacers were from Amazon @ $110 for all 4.
Aluminum spacers: Many people get all sorts of emotional about using spacers, especially ebay or amazon aluminum spacers. In all my years, I've never seen a spacer fail. I've seen people fail by not cutting the old lugs under the spacer height, over torquing or under torquing or not using loc tite on the lugs holding the spacer on. Also note: I'm not using this van to rock crawl or jump around Moab. If I had plans of really beating on the suspension and going real big on tires then yes, I would upgrade to steel spacers.
Let me know if you have any comments or questions.
