What did you do to your Full Size today?
Luckychase5
Great thread. Does last week count?
Replaced the glow plug relay so the thang'll start when it's cold.
Installed a set of 8" KC lights I picked up off Amazon for 282 bucks. (Note the brutal workin' conditions on the shore of Lake Mead.)
And then while makin' a high-speed baja run 'cross the desert to get from the Mountain Springs Saloon to the Pioneer Saloon I busted the crap outta my grossly overloaded Aluminess spare tire carrier.
Folks at Aluminess have been great. Already lined up to drop the rig off at their shop so they can design and build a new version that'll handle the weight load of my 140 lb spare and my 30 lb bike ... and my drivin' style. Cheers to 'em. :beer:
Love the "shop" location! Awesome looking spot for some work on the rig
MagnutsWJ
Added a bestop supertop canopy. Love it so far!
daddyusmaximus
I used mine to trail break my sister-in-law through the headlight high snow drifts in her driveway. My entire undercarriage and radiator packed with white stuff... still didn't get through. Lockers worked great, mud tires in snow, not so much. Now I want a set of tire chains. Plow truck a friend has had to back up and hit it a dozen times, but we opened the drive.
Wh1t3nukle
I gotz dis
Yeah, they wouldn't have accounted for that much dynamic acceleration... lol
I finished my lower long arm build and mounted some 37" meats as the stepping stone to the Ford HP60 swap in the fall.
These welds are by a good friend of mine. I don't have enough arc time to get this good.
Luckychase5
Looks great! Did you build your links as well? What did you make it out of?
Wh1t3nukle
I gotz dis
Thanks Luckychase5.
Yes I built my links. The uppers were previously the lowers. Smashed up the factory ones.
I had a friend weld up the long lowers and the brackets for this part of the build.
2"x2"x.25" square tube is the link material
kojackJKU
Autism Family Travellers!
Getting the transmission rebuilt......again.......so, while its in the shop I made a shopping list for it.
Sent from my A210 using Tapatalk
Halligan
I had the gauge cluster from my wife's Z71 Tahoe rebuilt because the fuel and tachometer had stopped working. Today it arrived via Fed-Ex so I reinstalled it. While the truck was down with no cluster I also fixed the rear HVAC that was not working properly. I also pampered the finish with a clay bar and 2 coats of wax. The truck was bought new by me and almost 11 years later it's in great shape. A little rust on the rear doors by the pinch weld but thats it after 11 New England winters. Definitely the best vehicle I've ever owned.
Also washed all of the road salt of my Ram 2500.
Rot Box
Resealing my power steering pump as preventative maintenance. Gonna change some hoses as well. So far it's been an easy job..
Installed the Alpine stereo unit my beautiful wife gave me for Christmas. It replaced the crappy Pioneer I had installed by Cheech and Chong at the Up in Smoke Stereo Store. :sombrero:
Luckychase5
Thanks Luckychase5.
How far did that push the axle foreword using the lowers for uppers? Did it center the wheel in the wheel well? I see a lot of aftermarket links that move the axle foreword a few inches for that effect. What did you use for your ends? Still bushing style or something else? Looking to do something similar. Sorry for all the questions, cheers!
On second look I see what you used for your ends, where did you get those if I may ask?
Wh1t3nukle
I gotz dis
I pushed about 1.5" forward. Depending on how you look at it, it's centered with respect to the tire size.
Frame joints are Metal Cloak duroflex 1.25" shank diameter adjustable, RH and LH
Axle side are Ruff Stuff 1.25" rod ends also 1.25" shank diameter adjustable, RH and LH
PM me if you'd like more details so we don't come off cluttering this thread's intent. :)
Houie
