What JK specific tools do you carry?
AggieOE
Trying to escape the city
That being said, I'd answer with all the crap I carry, but probably none of it applies to a more modern and reliable jeep.
Yeah.... I carry my USAA insurance card with roadside assistance and Jeep's service phone number.
But like all real mean, I always keep a knife, duct tape, Zip-ties and of course, WD40. Oddly enough, I've never used WD40 while traveling. I have definitely used all of the others though.
MattHowell
Thanks for all the awesome answers guys! Sorry for just now responding to my original post. Truth be told, I completely forgot I posted this (I've had an insane two weeks). This helps a lot
KG4NEL
JK-specific? Probably just the AEV Procal (it's awesome for holding a specific RPM during winching). Everything else could be used with another truck.
Topo.Ranger
Here is a list that I found and I use Atlas 46 tool bags for my tools.
https://www.atlas46.com/products.html?#!/Bags/c/14466133/offset=0&sort=normal
JK Specific Tool List
Suspension and Steering components - I have all these sizes in 1/2" drive sockets and wrenches, with some extensions and will add some elbows (I think that's what they are called). Some of the smaller ones I have in 3/8" drive as well.
Front Suspension and Steering Components
Upper Control Arm - 18mm
Lower Control Arm - Frame 21mm
- Axle 21mm (mine is 22mm as I have an aftermarket skid with different bolts)
Sway bar Links - 19mm
Track bar - 21mm
Shocks - Upper - 17mm
- Lower - 18mm
Steering Stabilizer Shock - 18 mm
Steering Stabilizer Pinch Bracket - 15mm
Draglink Pinch Bracket - 15mm
Control Arm Lock Nuts - (stock doesn't have these but my RK Control Arms do) 1.5" box wrench or adjustable (not sure on this size)
Rear Suspension
Upper Control Arm - 21mm
Lower Control Arm - 21mm
Sway bar Links - 17mm
Shocks - Upper - 16mm
- Lower - 18mm
Track bar - 21mm
Track bar Bracket- (stock doesn't have this) - 22mm (Rock Krawler)
Axle Nut - 35mm or 1 3/8" (some might be 36mm)
Driveshafts - 8mm/15mm??
Brake Components
Front - Calipers - 13mm/1/2", 15mm open end wrench
- Pad Carrier - 21mm
- Brake Line - Caliper - 15mm
- @ hard line - 12mm/17mm
- Hub Bearing Unit - 13mm 12 point socket
Rear - Calipers - 13mm/1\2", 15mm open end wrench
- Pad Carrier - 18mm
Brake Lines @ Master Cylinder - 12 mm
Brake Booster/Power Steering Bracket - 13mm
ABS Sensor - Allen Key 8mm
Battery and assorted grounds - 10mm
Alternator - 15mm
Throttle Body Adjustment - E10 reverse torx
Transfer Case Fill Plug - 10mm Allen head
Transfer Case Drain Plug - 10mm Allen head
Transmission Fill Plug - 14mm Allen head (Manuel)
Transmission Drain Plug - 17mm Allen head (Manuel)
Bottle pump to fill transfer case/transmission (Manuel)
Torxs Sockets for doors and hard top, and windshield - T50, T40, T35
General Tools
1/2", 3\8" drive torque wrench rated between 20 and 150ft. lbs.
Vise grips
Needle nose pliers
Soldering Iron, flux and solder
BFH
Wire strippers
Duct tape/Gorilla tape
Assorted zap straps/Zip ties
JB Weld
Electrical Tape
Tie Wire
Assorted Fuses
Multi Meter
Breaker Bar
Code Reader
Heavy Duty Ratchet Straps
Funnel/long neck funnel
Utility Knife
Small Tarp
Hand Cleaner/Latex gloves
Rags/Shop towels
Spill Kit
unkamonkey
Not vehicle specific but in my 3B I carry about everything in a big tool box that doubles as a rear seat. About as many tools and parts as are in my garage. I think I've dug a screwdriver out of it but other friends seem to like the fact that everything is in camp for them to do repairs. It also helps to have a few other idiots around to help screw up any repair job.
Have a beer and watch the show.
Actually, I have a holdover from my old Harley days, a 4" Crescent wrench in my pocket. It gets used more than you would think by people.
