What other vehicles can swap wheels with my E350
Heloflyboy
All ford,chevy,dodge older then mid 90's. Factory 8 lug chevy wheels have a smaller diameter center hole so those will not work but if they are aftermarket they should be fine. Ford and dodge have same center hole and lug pattern. Watch for offsets with after market wheels. Also watch out for 8 lug 15" wheels they won't clear your calipers but you most likely won't find any of those. 80's will have a lot of 16.5 wheels(hummer bead locks also) your tire choices will be less with that size. Good luck
dvorocks
I'm thinking of putting some h1 rims on my e350 but mine has dual wheels so I read that its easier than the srw vans
justcuz
Judging by your replies can I assume that Ford still uses the 8x6.5 bolt circle on the E Series instead of the 8x170mm used on the F Series trucks?
JCCB1998
