dwh
Tail-End Charlie
Regulator is just another word for charge controller - like Americans say 'Motor Home' and English say 'Caravan'.
That charge controller in the link looks decent.
It's got temperature compensation, which is a feature found on better charge controllers.
And it's smart enough to NOT do equalization on AGM batteries.
Of course, a 30a charge controller is much larger than is needed for an 8a solar panel. If you don't plan to expand the system by adding more solar panels, you probably don't need an oversized charge controller.
I would imagine you could put together a comparable system for less if you buy components instead of a kit. Or find such a kit already available.
Here's one that uses top of the line components - Kyocera solar panel, Morningstar MPPT charge controller, Midnite Solar breaker box, etc.:
http://www.solar-electric.com/rvkitwi140wa1.html
