What to do about another cranky bolt failure?
henry510
Do you feel said wobble in the cabin? That seems like an excessive amount of wobble, i will try to video mine after work. I'd question how they got the old bolt out and new bolt in, but the balancer is basically self centering on install, so i'm not sure thatd matter.
Thanks for the reply. The car feels normal and drives fine.
They had to tap the bolt out with the engine still in the vehicle.
If you could video that would be fantastic. The dealer said the only way to answer definitively is to compare the behavior on like vehicles.
Jeffer949
You need to look at the mounting bolt. or the inner hub to see if it is wobbling. Its unlikely but possible that the outside is not perfectly eccentric to the inner. I feel like it should be though.
Houie
