What to put on my winch bumper?
patoz
Don't want a winch.
In that case, you could box it in and make a compartment to carry some of your other recovery gear, like snatch straps, ropes, chains, shackles, gloves, etc.
SoCal Tom
I like that idea, does anyone make a box that doesn’t block too much air flow?
patoz
I like that idea, does anyone make a box that doesn't block too much air flow?
Not to my knowledge. I think this would have to be something custom built to fit your space. If the box was no higher than the bumper itself, I don't think it would block any more air than a winch would, but every application is different. You could also make it out of expanded metal and just use it to carry wet, dirty ropes, etc. while off-roading.
Chili
I bet a winch would fit in there perfectly.
Maybe an ammo can for storage for any recovery equipment?
Not a bad idea actually.. A fat 50 can with a lock mod though the mounting holes for the winch may be a bit too spread.. Maybe attach the can to a plate and mount the plate to the bumper. Good place for a kinetic rope, shackles and some gloves.
patoz
Chili, is that a standard 50 or a fat 50? I'm planning on getting a Viair also, and I like that idea.
patoz
Great, that's what I'm going to do then. I was thinking of using a Pelican case or something similar, but this is much cheaper and will protect it just as well.
Thanks for the info...!
