I have started welding the base of our flatbed cabover camper on an Isuzu NRR, and I am trying to decide what to do about the bottom of the steel frame that will sit on the metal/wood flatbed.
Some of the ideas would be easier to do now while I can easily flip the base over.
One idea is just to tack weld sheet metal to the underside and caulk it from the inside to prevent moisture somehow seeping up into the floor foam.
Or I could try to find some thick tough plastic, maybe 0.25, and screw or sikaflex it to the underside.
Or wood, metal or plastic then take it somewhere and get it coated in a truck bed liner material.
The plastic would probably be the easiest, but if I attach it now, it will be hard to prevent it melting when I start to weld the upper structure to the base.
Ideas?
Ideas?
