My plan was to run 35s on my CDN M101 to have a common wheel/tire set with the truck. To do so I'd needed to run 5x150 adapters. I found an online source and had some made. They adapt from 5x5-1/2 to 5x150 and are 1-1/2" thick.
My concern is that there isn't very much meat holding the wheel studs in, especially considering the leverage arm from a 35. Granted the max trailer weight would be around 1300 lbs, but it also could have significant side loads on a trail. And if the adapters go you're hosed.
Here are some pics... any input? The bore for the studs appears to be 1-1/8" (it's 7/8" to the stud head which I'm assuming is about 1/4"). That leaves only 3/8" of material for the stud. That alone is probably OK. The bigger concern is at the rim of the bore. Inboard it's only 50 mils! And outboard it's just over 1/8". It just doesn't seem sufficiently robust to me. I think they needed to use a different size of blank to make this adapter. Thoughts?
