Wheels and tires help! ??
bbbthreat
Definitely not stock. They probably lifted 4" like Quigley does in order to get the front axle under it.
https://www.discounttiredirect.com/buy-wheels/vision-soft-8/p/49688
Wheel option with a -12mm offset. Get you that wheel poke you are after.
https://www.discounttiredirect.com/buy-tires/nitto-ridge-grappler/p/30568
34" tires will work but you will need to trim a little to get it to work. These tires sound like they would work for what you are after. I use Falken Wildpeak AT3-W and like them a lot, but I don't see a lot of mud. Had Nitto Terra Grapplers on a Tundra and they wore well, and did well in mud, but were meh in sand. https://www.discounttiredirect.com/buy-tires/nitto-ridge-grappler/p/30568
Couple this with 1.5" spacers in the rear, and I think your rig would look pretty darn good.
You are going to have to measure to figure it out. Here is some stuff to work off of.
Houie
