Where can I buy Panasonic HIT N250 Slim solar panels here in the U.S.?
MTVR
Yikes- the Victron SmartSolar MPPT 100/50 solar charge controllers are $300 each!
Are there other options I should be looking at?
MTVR
We are looking at a low-profile vent that is only 2-7/8" tall when closed, and we intend to mount the solar panels with an air gap underneath them of an inch or so, basically putting the surface of the solar panels as high as the top of the vent (when it's closed).
MTVR
So would I want to connect each pair of panels in parallel and use the SmartSolar 100/50s, or would I want to connect each pair of panels in series and use the SmartSolar 150/35s- both controllers are basically the same price...
dreadlocks
for paralleling solar chargers, and/or lithium you should be buying Victron gear w/out a doubt.. and yeah I know they aint cheap, Ive got a 30A and I needa buy a 50A next, for my 650W 12V system.. I'm capped out at 450W right now, I'm putting my fixed roof and portable solar on different controllers because with them in such different directions I only get one or the other unless they both getting full sun, so my partial sun performance is poor.. I could get another 30A one but I want a 50A so I can feed it shore power and use it as a programmable smart lithium AC charger too.
dreadlocks
60*2 = 120V max, so yeah a 150/35 would handle two panasonic's in a series, but it'd only output 35A instead of 50A, you'd want the 150/45..
You can configure SmartSolars to limit current output, so if you dont desire the whole 50A, and you want 40A max because you have another 40A max you can configure em as such and even if they get more power than that sent in one end, it wont output more than that.. at some point I could see those smart victron guys letting multiple controllers dynamically adjust output to keep within a global max output.. they are just the kinda nerds who'd do something neat like that.
MTVR
for paralleling solar chargers, and/or lithium you should be buying Victron gear w/out a doubt.. and yeah I know they aint cheap...
I'm currently looking at other Victron equipment- I mentioned the Victron Orion 24/12-70 DC-DC Converter in my 24V alternator thread:
dreadlocks
My 50A charger is gonna be configured to output no more than 40A (0.4C for 100AH), I have a really nice high output AC/DC power supply that I'm feeding into the Solar Charger, through a little diode box I made that keeps the AC charger and Solar Panels isolated.. so I can feed the solar charger either DC power from the portable solar panel when its plugged in, or its getting high voltage DC from my dumb power supply.. I getta pick and choose.
This is one of the only way's ive found to charge my lithium from shore power at high output, with something I can fully program my self to whatever parameters I want.
shade
Have you priced 2000W of HIT panels or 400Ah of good LFP batteries?
John has already mentioned it, but approaching this as a system is the smart way to do it, and the system is only as reliable as its weakest components. Considering what you're undertaking, spending a little more up front has the potential to save you a considerable amount of trouble and money over many years.
dreadlocks
Yeah he's looking at >$2k in solar panels, twice that in batteries.. $600 for a pair of high quality solar chargers to take advantage of the investment you've already in with seems pittance.. how much it cost to put 8 new tires on a MTVR BTW? dont that kinda make all this look cheap heh.
nathane
Why parallel? Surely you would be better running low current high voltage series connection. No need for 50mm2 cable!
Alloy
For a large sysy
If it shades one panel and I see the 4th controller go to zero, I'll know that I need to drop the vent lid if I want to regain that power.
4th Controller?
Our 2.6Kw - 12v uses two controllers. A 150/100 for the portable and 250/100 on the roof top. The 250 was to allow 2 more panels on the roof but I it's not likely I'll add them.
I would have gone 24v or 48v if the hyd leveling system didn't have 4-12v motors that draw 70A ea.
Everthing was done to maximize the output in the worst conditions. We did a 10 day trip in June. In 3 days of rain and sorrounded by 100' trees the system produced 70Ah-100Ah each day.
The portable picked up light (no direct sun) in the morning and the roof top got it in the afternoon.
My friend was there for 5 days and used a 100' cord from our inverter to power a 5A charger for his batteries.
dhuss
