RandyP
I have a 125 AH Lifeline GPL-31XL battery in the 4WD camper, 80 W solar cell, Redarc BCDC 1225 25A in vehicle 3-stage 12v charger. The Redarc includes a MPPT solar controler. There is a relay to select solar cell or vehicle battery as the Redarc power supply. I am satisfied with the off-shore power battery charging scheme (except that I may need to upgrade the solar panel to 100+ watts and get a higher ampacity alternator in the truck).
I would like to have an onshore power battery charger to maintain the lifeline in full charged condition when the camper/truck and lifeline battery sit in the driveway between adventures. I could rely on the solar cell but have only seen it charge the battery at about 5 amps max (that's about 60 watts) when the sun is in just the right position. Charging current is usually just a few amps. No sun, no solar charge. I have an IOTA 12v power converter 3 stage charger that can bulk charge the Lifeline battery if it is not fully recharged on the trip home with the vehicle battery/alternator thru the Redarc.
I would like to have a battery maintainer to keep the battery at full charge between trips and do some desulphation as needed.
The lifeline battery website points at the CTEK multi us 7000 battery charger. Looked for the CTEK 7000 and only found a multi us 7002 currently available to buy. The 7000 user manual has a charge cycle graph that is quite different than the 7002 charging phases graph. Looks like the 7002 charging phase graph might be screwed up because it doesn't match the English description below the graph.....current and voltage graph designators and terminology in description of phases.
So should I get the CTEK multi us 7002 charger to maintain the lifeline battery ? I want the battery to have a long life. Any other charger/maintainer suggestions for one lifeline battery ?
