LexusAllTerrain
100 miles on the White Rim, one day average speed 10 miles= 10 hours
Is this realistic?
Is this realistic?
eurorom said:100 miles on the White Rim, one day average speed 10 miles= 10 hours
Is this realistic?
eurorom said:Thanks and I guess what I am asking if 10 hour drive on this trail would be safe, I was told that they are some areas that i have to be carefull and I an counting in doing an one hour lunch, so is the speed that I am planning on doing is it reasonable?
The last part of the trail even if is dark it seems like it is very easy and straight with no twisty turns?
FWIW, on Nov. 22nd (as an example) sunrise is 7:07AM and sunset is 5:01PM. So you will only have 8 hours of light. I think 10 hours is doing it without much stopping. Starting at Shafer switchbacks, the final run after the Mineral Bottom switchbacks is a graded road, high speeds are achievable with the only caveat being wildlife and other vehicles. I would assume the final 12 miles can be averaged at ~30+MPH at night. I would get started at the crack of dawn and it should be fine.eurorom said:Thanks and I guess what I am asking if 10 hour drive on this trail would be safe, I was told that they are some areas that i have to be carefull and I an counting in doing an one hour lunch, so is the speed that I am planning on doing is it reasonable?
Yes, you can run it in a day, but why would you want to? The road itself is an uninteresting two track with no difficult obstacles. The reason you're there is the scenery and the overall experience. If you just want to tick it off the list then go for it, but I don't see the purpose.eurorom said:100 miles on the White Rim, one day average speed 10 miles= 10 hours
Is this realistic?
neliconcept said:dude if you want get there on monday morning, ill give you my # number and you can share the campsites with me
8643766393 give me a call and you can stay 5 nights if you have the gear.
if you cant get there on time, i can still get your plate # and give it to the visitors center and tell you what days at what campsites ill be at.
cruiseroutfit said:Planning to run the White Rim Trail in the coming weeks... I've don't both ends (in & out of the trail) but never the middle section, nor done it all in one sweep.
Which campspots would you pick versus others?
Which hikes would you do again?
Any other suggestions would be appreciated.
TIA
eurorom said:I am planning on doing it in one day, so that I may have an excuse to come back!
...or at least half!
