Who makes decent 20" lightbars
trae
Hello friends,
I'm trying to add some aux lighting to my vehicle. To that end I purchased a $50 20" lightbar off amazon. It looks decent, but I measured the current draw it turned out it was pulling 4 amp at 12V which would make it at 48 watt lightbar when the seller advertised it as a 120 watt bar. When I went search on amazon I discovered that it's a common complaint with these cheap bars. A 400 watt lightbar with a 30 amp fuse? No thanks.
Anyway, I spent some time googling and appears that Rigid is the leader in automotive led lighting. When I searched for a combo spot/flood dual 120 watt row bar I found that they sell one for $500. That's 10 times more than the cheap amazon one I bought. Is there something in the middle there you can recommend?
Thanks
trae
Much appreciated. I’m with you, there’s something I don’t like about bars but the supposed value proposition sure makes them worth a try.
I shall go read the thread now.
check out speed demon, we sell em at my work, ive got a 12 inch and a few driving lights on my truck, tons of options, really well priced, and the drc line is lifetime warranty.
https://www.speeddemonlights.com/ they are canadian company, wharehouse is in airdrie alberta, and they ship anywhere.
UltraHDGames
Check out Kodiak Led lights, they have a 21" double row bar that is crazy bright and very high quality. Seen kodiak bars and pods on my friends truck and they have awesome output and build quality.
http://kodiakled.com/
Here's a picture of a 21" double row, no headlights or anything else
huntsonora
perhaps Im just old school, but the light bars have never appealed to me.
I much prefer round lights.
And if you want some real light, go for the "ARB knock off" lights.
Legit lights, and the pricing has come WAY down.
these ones...
http://www.ebay.com/itm/2X-9-185W-B...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
entire thread on them here...
http://forum.expeditionportal.com/t...B-Intensity-LED-Driving-Light-Light-Force-250!
Are these them?
https://www.amazon.com/Northpole-Li...22723&sr=8-21&keywords=9+led+round+light&th=1
eaneumann
I’ve bought a few different lights from superbrightleds.com and have been impressed. They’ve been around for a long time and offer a great warranty. My Rigids are nicer. I have a 40” superbrightleds that was around 200$ that is very nice.
Edit: I’ve never measured lumens or amp draw.
huntsonora
Thanks. Looks like the lumen output on the eBay vs Amazon lights may be different unless I was reading something wrong
hemifoot
i had uni-bonds for a while.rarely used them so i switched to hella driving lights.way better for road travel.i still use the uni-bonds as rear floods.i'd get the rigids if i were desert racing,but for that $ id be able to but half a dozen cheaper cree lights.some say osrams perform better than cree.but my eyes are old.
paranoid56
if you want a good bar its not cheap. but you can get some cheap bars that arnt bad, just not awesome.
Check out Baja Design lights. mostly made in the USA, lifetime warranty, changeable lenses.
I have a mixture of BD lights and those 9" ones above (i will say those 9" ones are awesome too lol)
if you have any questions on bd let me know, i am a dealer for them and can get you a good price lol
https://www.bajadesigns.com/products/S8-20-Inch-LED-Light-Bar.asp
96Green
Here's my 2c. A $50 lightbar is probably going to be crap. When it comes to auxiliary lighting, there is a big different between the bottom of the barrel and the midrange lights, in terms of light output, range, and spread. ...not to mention build quality. With all of that said, there is probably not a need to spend $500, either.
I've got a 12in Auxbeam X-Series on my Exploder, and I'm quite happy with it. It is also available in a 22 inch size. It's configurable for spot or flood use and has the capacity for colored filters, it is quite bright, and it throws light a good distance. Given the 22 inch model is a bit under $100, I'd say it's not a bad deal.
My only gripe is that the front glass isn't actually glass, it's thick perspex. So, it would be susceptible to rock chips or scratches; If you are mounting it at bumper height, you may want to use a set of clear filters to protect it.
Here's a quick YouTube review of the X-Series (not mine).
WonaWarrior
