Heloflyboy
I just found a 2009 f550 that had an engine fire. Not sure what the mileage is on it being most of the interior was burned. Does anyone know if the front axle would work for a conversion? It has 10 lug wheels, I am not sure if the hubs or disc could be changed to 8 lug. The locking hubs and calipers have already been stripped from axle. The fire appears to be more on passenger side of truck, the abs line was burnwd in fire as well as brake lines. I dumped gear oil and it does not look bad and axle does not look as though it was torched. Bushings on track bar are melted on frame and axle housing, but bushings from radius arms to axle are good. It has 4.88 gears that I would change out. I can get axle for. $250.
Missed this part this will be going into an E350 diesel.
Any thoughts would be great.
Thanks
Thanks
